What to use to insulate elbows, tee's, unions...
BXNYC
Member Posts: 10
Hello All,
Would regular wall insulation cut to size do the job? Or any other suggestion is appreciated.
Thanks.
BXNYC
Thanks.
BXNYC
Insulation for Fittings
You can get PVC insulated covers for fittings. Check the following:
Buy Insulation Products on Line
[url=http://estore.websitepros.com/1805348/-strse-PVC-Fittings/Categories.bok]http://estore.websitepros.com/1805348/-strse-PVC-Fittings/Categories.bok
McMaster Carr - Catalog Page 3460 -mid page
Edit: Don't use this link unless you are interested in this product. For some reason it locks you onto the McMaster site and you can't use the BACK button!
[url=http://www.mcmaster.com/#insulation-jacketing/=4gs1pg]http://www.mcmaster.com/#insulation-jacketing/=4gs1pg
I 've dealt with McMasterCarr`and they are very good.
- Rod0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
