Powers pneumatic control help please
Timco
Member Posts: 3,040
I have a cust with a powers pneumatic t-stat and valves on the coil. T-stat allows air out when below set temp, and closes on demand for heat, but valve is stuck. Is there a head replacement for this, or an online source I can match the head unit up with? Black dome and a spring under it around the plunger. Maybe clean & rebuild? Ground floor of 10 story bldg.
TIA, Tim
TIA, Tim
Powers Thermostats/valves
Timco,
Try National Energy, out of PA. Their website is neccdelivers.com. They have a large variety of all brands of pneumatic controls. Good Luck!
Ross0 -
NECC
NECC is a great company, we use them all the time for our pneumatic controls.0 -
necc
NECC is the go to. 1-800-227-9800 ask for a catalogThere was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
