help with intelidyne controler
gkratt
Member Posts: 6
i have a honeywell L4081B, dont know which wire to connect the red and yellow off of the control, unit has power
Wiring help
Find out which side of the aquastat is the load side. Remove wire, connect yellow to aquastat and then connect red wire to wire that you removed. The load side should be labeled on the wiring schematic on one of the panels of the boiler/furnace.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
