Buderus GB125BE's
john_161
Member Posts: 3
Awesome
Awesome.
Does Buderus supply the Tigerloop Ultra like that or did you procure bits to make it up?
Can you let me know the guage configuration and whatnot? I like the idea of not having to put a tee and then having two odd lengths of hose etc.
edit:
On close examination it seems the vac guage is on a tee. Its just turned 90 degrees from what Im used to seeing.. It looks great. Do you have another filter in front of it?0 -
Nice pipe work!
John, I like the strapping/hanger for the expansion tank. I have been nervous to try this, have you had any problems with trapping air at the tank? I am a big fan of dual boilers for larger loads. I am not familiar with that model, how are they controlled? Cascade control? Nice job.There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
