Convert to vaccuum system?
Has anyone converted a one-pipe system to vaccuum?  How involved is it?  Is the improved efficiency worth it?
Bill
  • Unknown
    edited November 2009
    Paul System?
    Another poster was interested in doing a Paul System. They still make Paul valves for radiators.  They are supposedly much more efficient.  Look back a few days to last week there was some discussion there on the Paul System.
    - Rod
    Steamhead Member Posts: 18,197
    That thread
    is called "Paul System Retrofit" and it's several pages down from here. For some reason I couldn't paste the link- but you'll find it.
    Consulting
  • Patrick_North
    Patrick_North Member Posts: 249
    I'm curious, too
    I can see restoring a vacuum system, but I'm curious about why you would convert, too. What little research I've done suggests the Paul system was used to augment existing one pipe setups- would this benefit still apply with more modern setups?
    I wonder- with good main venting and insulation, would it be worth the $$$ in a residential settion?
    Patrick
    It would have to have
    an electrically driven vacuum pump, since there may not be enough steam pressure to operate an ejector. When the Paul and other air-line systems came out, they were originally used on systems that produced higher-pressure steam for power or process work, which is why the ejectors worked so well.
    I have a feeling someone, somewhere, is going to build a modern Paul system in the near future. In the old days the savings were something like 35%.
    Consulting
