Honeywell visionpro thermostats
Maine Vent
Member Posts: 130
I may have missed this on The Wall, but as I search on Amazon for a Visionpro for my Burnham steam boiler I see lots of models. None of different models seem to mention good for a steam system. I read a lot of the post and know nbc is a strong advisor for this model. I will hit the Honeywell web site and see what I can dig up. Also, thanks to all the the Pros, and also to all the non Pros for taking time to read our posts and replying to them. Dan has a GREAT site with some good old down to earth folks. Thank you.
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
404 sq ft EDR
Visionpro Steam Model
Hi- On the Honeywell Vision Pro TH8000, the model you want for steam is the TH8110U: For 1 Heat/1 Cool system - See attached PDF manual. The number of cycles per hour can be specified. 1 is the normal setting for steam. (See Page 8 Item : 0240)
- Rod0 -
Thermostat
Thanks Rod, I really appreciate the feed back. I will try one out.Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal0
- 62 Biomass
- 114 Geothermal
