Checking overfire draft
ml_4
ml_4 Member Posts: 2
Looking to see what you guys use to block the large openings on older boilers when checking overfire draft. I've been using a rag up till now but there has to be a more refined way. I am using an UEI 125 tester.
Thanks for the tips
Mike
    Steamhead Member Posts: 18,209
    Next time you install a bathtub chamber
    save the disc from where you cut out the hole for the burner head. Make a hole in the middle for your probe, and you're done!
    Consulting
