pump troubles
croslod
Member Posts: 2
New here, just stumbled onto site today. I have a wood boiler outside 100' from house all plumbing is 1'' pex or black iron pipe, after it goes into basement it goes through a plate hex then up 2' to a hex in the first furnace then up 10' to atic then 50' with another 4' of rise to a hex in second furnace above garage then back out to stove. I have a astro 30 that runs to a hex in the shop and a taco 0013 at the stove and a 0013 in the atic before the rise in the garage and the 0013 at the stove locks up and the one in the atic wollered out the bushing in the impeller. I have no idea how to make this setup work. Please help!!!
how bout this
Me agian, after more research i am contemplating adding a second plate hex and making the second hex above garage a closed loop. Does any one have easy formulas to figure out what size pumps i need and what all i need to do to make a closed loop. That loop will have 100' feet of 1" pex non o2 barrier and a total of approximately 14 feet of virtical rise. From what i can tell i will need a30lb press pop off valve,expansion tank,air bleed,plate hex and a pump. Any suggestions?0
- 114 Geothermal
