Gas furnace (3 zones) -shuts off after 2 minutes
Catherine
Member Posts: 7
Weil-McLain, gas furnace, installed in 1979, fires all burners, then shuts down. Cleaned thermal sensor. Pump is less than 2 years old, capacitor appears new. Any ideas. I have turned the thermostat up to 80 degrees. The radiator is slightly warm, so I think that the pump must have circulated some water. Any ideas?
Catherine
Catherine
Check
the water pressure . Should be about 12psi , if you done have pressure the water can't move .0
