HEAT LOSS?
anthony_12
Member Posts: 9
IF A HOUSE HAS A HEAT LOSS OF 170,000 BTU'S BUT HAS 5 AIR HANDLERS WITH COILS OF 386,000 TOTAL <a href="mailto:OUTPUT@180">OUTPUT@180 DEG.WHAT SIZE BOILER WOULD YOU PUT IN?</a>
I'd
make sure the heat loss was correct and then install the proper size boiler.Sounds like a perfect spot for a condensing boiler,you can run much lower water temps with coils that are that much oversized0
- 167 Indoor-Air Quality
