Boiler Gasket
GTD
Member Posts: 33
I have a weil mclain 368st oil fired boiler, what do use for a gasket for front mounting plate to the boiler , the putty they give with the new chamber kit is lousy. thanks tom
Weil burner door gasket
I always replace it with what came on the boiler originally. I use burner rope, set in a bed of high temp sililcone, and then I coat it with Never Seize....you will never have to replace that gasket again.......it didn't come with NeverSeize, but the new ones do.0
