MONOFLO SYSTEM
DRH
Member Posts: 1
i have a one pipe system 2-story upper level and lower that is adding one an addition with about 50ft of fin and tube radiation. homeowner wants a high efficient munchin boiler to operate system. how do i pipe this system into munchin requirement of a primary/secondary. are there piping diagrams available to show how? system is a monoflow hot water system
Munchkin caution
I have 2 Munchkins (Peerliss Pinnacle the same as) in my shop with partially plugged HX and worried about the rest I've installed. They are only 2yrs and 5 yrs of age and warranty does not cover this. The HX tubes are very small. Be sure to use a good strainer and have NO minerals in the water and flush out system with TSP before installation.Compare other mod con designs.0 -
I would`nt be too hard on HTP products,,,,
Awhile back they had issues with their blower-fan, but these have been resolved(that I hear), and the use the same (Italian designed) HX that many other manufacturers have adopted. They offer great efficiency, at a lower bang for the buck cost,,, properly piped-up, I would not be afraid to use-one at all.
A flush & clean of the system should be standard anyway, and a wye strainer will only help,,,, have you checked their website for some M/F installation info?
Good Luck! :-)0
- 120 Geothermal
