ODR Setting
JIMBO_2
Member Posts: 127
I have a new TT-110, and I have the factory ODR installed, per instructions. But do I need to make setting changes to the boiler, too, in order to obtain optimum efficiency from the system?
There are multiple settings,
You can achieve with the TT MCBA controller.
Do you have the control supplement?,,,, set your heating curve,,, parallel shift,,, WWSD,,,
etc. are all there IF you know HOW to access them.0 -
Thank you, Dave
No, I do not have the correct supplement for my boiler. I have the newer version, via TT, but my boiler is from 2008 and has the earlier MCBA board. I can call them if necessary, but I thought I would ask here first . . . amongst fellow professionals in the heating/plumbing/piping industry.0 -
Good call,,,
PM me,,,, I`m sure I have what you`re looking for.0
- 120 Geothermal
- 394 Solar
