convert open system to closed system
tryagain
Member Posts: 1
I installed a diy open radiant system in my new house 5 years ago, slab on grade with in floor heat. I am not happy with the way it heats . In redoing my heat source and some of the piping i want to convert the system to a closed system where my newly bought water heater, AO smith cyclone xi bth-150 95% efficient unit heats my floor water via a heat exchanger and still supplies my domestic hot water. After reading about diseases when you have an open system where potable and radiant water are mixed i figure this is safer for my family.My problem is that when i was sold my pex tubing, it was designed for an open system and the tubing doesn't have a o2 barrier. What should i do to prevent oxidation in my pumps, valves, etc. i haven't bought the heat exchanger yet. should it be of a special material to resist oxidation. its hard to get help from anyone local when you did'nt buy the system or have it installed by them.
thank you for any help
X-Block
A good solution would be to install the Taco X-Block,a module which has a built in flat plate HX, pumps and control. It will separate the non-barrier tubing from the heat source. You'll need to add an expansion tank, relief valve, tridicator gauge and feed source, per the manufacturers' instructions. Using a water heater is not the best idea in hydronic heating. Try a mod-con boiler and an indirect tank for the upgrade...;0 -
closed side non-ferrous?
I think the X-block has a cast iron pump on the system side? I might be wrong, but I think it's only non ferrous on the expected open side.
If I am right though, you can do what the xblock does with heat exchange, and non ferrous pumps on both sides.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0
- 120 Geothermal
- 394 Solar
