120# Steam and Iron pipe
Big Ed_4
Big Ed_4 Member Posts: 3,364
What grade iron pipe is used for 120 # steam ..
  • Jean-David Beyer
    Jean-David Beyer Member Posts: 2,666
    Specialty steel boiler tube?
    I know some people who operate steam railroad locomotives (firetube boilers). Their boilers run at 150 psi and must be tested to 300 psi annually. They use specialty steel tubes for this, not the stuff you get at you neighborhood plumbing supply company. They need to be inspected by these guys: http://www.hsb.com/
    120 psi is awfully close to 150 psi. You are probably talking about stuff like this:
    http://www.seamless-steel-pipes.com/ASTM-A192.html
  • bob_46
    bob_46 Member Posts: 813
    Schedule 40
    seamed steel pipe should be fine Ed. If it's screw pipe I like to use Sch 80 nipples.
