Vent sizing
Big Ed_4
Member Posts: 3,368
Hi Guys ,
Can you help me out with a proper chimney size. Installing two 660k gas Fulton boilers and a gas 175k hot water heaters in a industral strip building , top of flat roof is 16' , will be using a side mount chimney .. What size chimney should be installed .. Thanks
chimney info
usually the local gas company has very specific regulations, based on BTU and chimney height, [including height above the roof, or any window. i am going to make a guess that you will have to vent them separately, or together with a 14 in chimney.--nbc0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
