Obsolete Honeywell L91B-1019 Substitute or Sourcing?
Gman_3
Member Posts: 27
Can anyone recommend a replacement for a Honeywell L91B-1019 pressuretrol for a modulating a burner for a vapor steam system that will modulate from 0 to 10 ounces (NOT lbs)? The 1019 model is no longer made. The 1035 model goes from 0 to 15 lbs which I doubt will work well in the 3 to 10 OZ
range.
Any thoughts on where to find a surplus unit or another manufacturer's substitute?
Thanks! Gman
range.
Thanks! Gman
