Baxi Luna
antman
Member Posts: 182
I have a request to assist on an install for an HT 380 Combi boiler, any experiences good or bad about these boilers would be appreciated
Baxi Luna
I have installed several with a fellow heating guy and I have this advise for you.....
Don't even think about doing one without some training in advance. Installation is easy as pie but the set up of the control and diagnostics require a special control to be temporarily wired in to set up the unit for your application. If your supplier doesn't provide the start-up support, make sure the rep is available to help you. I am a great believer in reading instructions B4 getting to the job, but this boiler, quite impressive as it is, is no easy 1-2-3 install. You must know what you are doing when you set it up.....liability can become a very nasty word in your life if you try to go it alone without prior training and good support.0
