piping used for swimming pools
Craig Drabenstadt
Member Posts: 7
in Solar
Can anyone tell me what types of piping beside PVC is acceptable to use with chlorinated water in swimming pools. I would like to add a heat exchanger to a solar loop for pool heating.
Polyethylene pipe
Well piping(pe pipe) works great, parents pool installed 36 years ago, still flexable with no leaks. If you are going to use salt to chlorinate dont use stainless fittings or exchanger. Nylon fittings for the piping and titanium exchangers are available.0 -
Salt or Chlorine?
Stainless would be the most robust, also the most expensive alternative. No go with salt though.There was an error rendering this rich post.
agree
100%0 -
pool piping
It is my understanding the only acceptable materials for salt water pool heat exchangers are titanium or cupro-nickel. You could use PEX with the plastic fittings for the piping, they are called HPP or poly-alloy sometimes I think.0 -
Careful
Whatever you do, don't plumb SCH40 up to the HEX. It's rated below 120 at pressure and the solar will certainly reach those temps. Ever see a pool empty itself in a mechanical room? Glad I haven't!0 -
pool migration
GSE: I actually have! it was a small (20,000 gal) therapeutic salt pool at a local spa, a cracked pvc fitting was the culprit, i've never had to wear a rain jacket inside a mechanical room before or since!0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
