What screw driver for this iso-flange?
D107
D107 Member Posts: 1,944
It's too large for a torx 30, and shape doesn't seem like torx. Know what grand flange this is? no writing anywhere. We need the exact driver since it's a bit frozen......
See attached photo.
Thanks,
David
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Hex Key
    When the iso flange won't turn with a large screwdriver, use an allen hex key.  It looks like an older Grundfos flange.
  • MikeyB
    MikeyB Member Posts: 696
    edited August 2009
    Flange
    Looks like a Clutch Type Bit ,its a little different but you might get lucky try Grainger item#1YHW5, or you might be able to use a breaker bar w/a flat head screwdriver bit.
  • Jean-David Beyer
    Jean-David Beyer Member Posts: 2,666
    If worst comes to worst, ...
    ... you might replace it with a gizmo like Taco's Shut-Off Freedom Flange. It has a ball valve in it with a regular ball valve handle on it.
