how can I calculate BTU sizing of Arco cast iron radiators by Am
CMadatMe
Member Posts: 3,086
See the post totally confused. That will confuse you. Go to http://www.burnham.com/tool_box.htm see if this can help you out.
Arco cast iron radiator sizing
does anyone have a Btu output chart on these radiators?
they are used in a hot water app0 -
what size?0 -
You could post the size and I can look it up in my 1935 Arco manual.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
