Radiator Valve Extensions
bob young
Member Posts: 2,177
WE that once in a while. use 1/8" or 1/4 " nipples & elbows. any supply house will have them. it will work perfect.just watch the pitch
Radiator Vent Extentions
We are swapping out several air vents on baseboard radiators and plan to replace with maid-o-mist or varivalve. For reasons of aesthetics and in some cases accessibility, it would be useful to use either a horizontal extention from the radiator or alternatively an "L" extension from the radiator (permitting use of a straight value, into the "L", rather than using an angle valve, into the radiator) (in either case the horizontol or "L" would extend through an end cover to the radiator).
Is it wise to use an extension in this manner or would functionality be degraded in any way? Are these extensions commercially available (I have not been able to find) or would they have to be custom made?
Thanks for any info.0 -
Great, thanks for the info.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
