Photos need for Training Manual
Tom Meyer_3
I'm writing the hydronics chapter for an illustrated training manual (ITM). I need good photos of field installations of a list of items. If your photo is accepted, you will get "Courtesy of..." credit.
Here's the list:
* Screw joint * Soldered joint * Air/Water heat pump * Water/water heat pump * Polypropylene pipe (PP) * PP fittings (compression, mechanical, transition)
I appreciate all your help.
Here's the list:
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
