Constant FLOW gas regulators
bob_46
Google Fairchild clic on regulators
Looking for a source
All,
An off the wall question. I am looking for a constant FLOW gas regulator for a non heating application. Ball park specs are 1 to 10 liters per hour and max output pressure less than 25 psi. Any ideas who might make such a device? Fluid is clean compressed air.
Thanks,
Larry C0 -
Fisher makes this type of regulator, called a constant differential regulator. Another option would be to use a pressure regulator flowing through an orifice, similar to how medical oxygen is metered. As long as the pressure downstream remains the same, flow would not change.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
