BASEBOARD ELEMENT
Paul S_3
WHAT IS THE LONGEST LOOP OF ELEMENT CAN YOU RUN WITH 3/4 AND 1/2 BASEBOARD?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
You can run it to the moon if you have a circulator matched to it, required pressure, and pumping away. How long a loop are you running?0 -
To keep the average water temperature
from going too low to be able to heat, I think you should keep 3/4" under 70 of element, and 1/2" under 25" of element. This would be on a continuous loop.Retired and loving it.0 -
if you want to keep the rated btu output all the way to the end of loop typical high temp system i thought the limit was 65ft of element 3/40 -
thanks guys i figured it was around there....i asked a couple people they told me for 1/2 inch its 80 ft i guess they were wrongASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
- 133 Chimneys & Flues
