leak in boiler
Don't know of any product for "long term" repair. Have used many products for leak stop with good temporary repair but in short, if it's a crack it's toast.
Check your warrantee....10 years on most steamers.
  • RJ_4
    RJ_4 Posts: 484
    leak in boiler
    Have a Peerless 211A 07 7 section steam boiler, with a small leak coming from the front left of boiler above the burners. Unable to determine at this time if it is a crack in a section or a leaking gasket. Any one had any luck with boiler sealer products like Hercules boiler seal for a long term repair. This is aone pipe system so any left over chemical by-products would end up going through #40 air vents in occupied spaces.
  • Even welding is a temporary repair. It maybe a tankless gasket, or other leak maybe from a plug or other tapping. The good thing is it is getting warmer so you have time to put in the new boiler before the cold weather.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • RJ_4
    RJ_4 Posts: 484
    Thanks. Boiler is 15 yrs old. Suspecting 2 things 1. not proper swing joints at header and or to much city water into boiler no boiler feed pump.
  • R.Stahmer
    Improper swing joints will most definitely toast it.
    Too much feed water will too, pump or not, if its not monitored.
    Dave
  • peerless repair
    that boiler should have gone for 35 yrs before leaking, but luckily the sections should be replaceable. put a watermeter on the fill line, after the repair. is it properly sized for the radiation?--nbc
