Embassy PEX tubing
kpc_75
Member Posts: 37
I have not used a lot of it because there is not a dealer around here. That is important. If a warrty. issue happens. They had some really BAD manifolds years back....leaks, lots of leaks.
Embassy PEX - quality?
Hi,
After trying to locate a local professional both on this site and on RadNet, the only one in my area uses Embassy liquipex tubing, manifolds, and associated stuff for radiant. Anyone have any experiences or impressions, good or bad, about this? The application would be staple-up with extruded plates, with a mod-con boiler as the heat source.
Thanks in advance!0
- 62 Biomass
- 114 Geothermal
