Cast Iron Boiler w/ Flate Plate Pool Heater
hot_rod
Member Posts: 26,592
for a load that large to keep the boiler in the condensing mode for extended periods.
The best way is a mixing device or return protection mechanism. Primary secondary alone will not assure you have adequate return protection.
You need a means to watch and adjust that return temperature to the boiler.
tekmar controls, injection mixing, 3 way thermostatic valves are a few options.
hr
hr
Will a flat plate heat exchanger for a pool cause damage to a convention cast iron boiler due to condensate? Return water temps are below 140* during the first start up of the day for about 5 hours. Would primary secondary pumping be a solution to prevent pre-mature cast iron failure?0
