Solder joint inside steam boiler
David Hohengasser
Member Posts: 52
I am going to put a 1/2" copper loop inside my steam boiler to gravity pre-heat my hot water. I am using a lower boiler tapping with a 2" duplex bushing and compression fittings. The 1/2" cc tube will go in 16", u-turn and come straight back out. I don't think I can bend the 1/2" copper that tight to fit through the 2-1/2" opening. Can I solder two elbows to make the turn, or will there be a problem with the solder joint?
don't waste your time..................
to short to work. What about adding a tankless?0 -
braze it, why gamble
all submerged coils or facsimile should be heavy copper [ type "k " ] & brazed.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
