Lavatory Facet with Threads for Hosse
If you`re speaking of an <i>automatic clothes washer</i> with direct hoses, typically an "air-break" is built into the machine from the manufacturer.<BR>That`s why they fill above the waterline. Dishwashers have had this too at one time. ;-)<BR><BR>Dave
  • Erich_3
    Erich_3 Member Posts: 135
    Lavatory Facet with Threads for Hose
    Is anyone aware of a lavatory faucet with a threaded outlet to connect a washing machine hose? Not sure if it a 4 inch or 8 inch faucet.
  • kpc_75
    kpc_75 Member Posts: 37
    It is a ...
    laundry tub/ sink faucet. Usu. 4 " cc. It should have a vacuum breaker screwed onto the threads to protect the water supply. kpc
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Just
    Find an aerator adaptet X hose thread fitting. I keep several on my truck. I only use it as a temporary type set up. Any good hardware store would have these.
  • As the others have stated,
    you MUST protect the potable water supply from back-siphon with a back-flow-preventer, and there are many adapters available for this.
    If its a lav faucet, the only thing that comes to mind is a bar sink type gooseneck spout that will give you some additional height.
    Dave
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Maybe just....
    in my area, but I have never seen any kind of backflow device in a residential washer connection.
    Just my observation,
    Jim
  • Jim Bennett
    Yeah Dave....
    guess I just assumed when he said washer hose, he was going to hook a washing machine to it.
    Probably not a good assumption :)
    Cheers,
    Jim
  • Great banter old friend!
    Take care,, nice talking to ya! :-)
    Dave
