Steam returns - copper last longer?
Mad Dog_2
Mad Dog_2 Member Posts: 8,409
I also like to have a valve above each wet return drop (under the water line) so I can POWER FLUSH the entire return under street pressure. I prefer gate valves...but can't always get them....you know. Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=299&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Ruth_2
    Ruth_2 Member Posts: 2
    I'm quoting a job to drop dry steam returns down and make a wet return. I'm Ok with proper piping techique but I'm wondering if it's best to use copper or steel. I know from experience that steel will eventually corrode. The pipes will have a wall in front of them so the best I can do is install a cleanout on the end. Also, I can handle the expansion of the copper. Will copper last longer?
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Yes
    I'd use copper as it will outlast steel in that location. But I'd still install a cleanout plug to flush the line if needed.
