Anyone seen these WHs?
Home Depot Employee
Member Posts: 329
ECR (Dunkirk/Utica) marketed those for years with no takers. Maybe it will take now in the future, we will see.
Have you seen the add-on units? now those make sense using your own tank that can be changed.
http://www.airgenerate.com/
Steibel Heat Pump Water Heater
Claimed COP is 3+... not sure how it could work with off-peak juice.
http://www.stiebel-eltron-usa.com/accelera.html0 -
nice idea...?
It seems to be a great idea. The specs show a max temp on the water side to be 140*. I didn't see the r rating on the insulation. I'm not sure you could get the high storage temp and keep it throughout the day if it were on off-peak. Looks like a great idea for a stand alone/standard h2o heater.
Definitely will open up the doors for specialized service work....good luck finding parts locally. Closes the door for direct replacement with a standard h20 heater because of power supply/breaker size.
Peace
works great, boiler turned off for the summer and so is my dehumidifier0 -
Beautiful, and I am not connected to these units in any way.
Yes it makes perfect sense that I didn't mention for those that can benefit from dehumidification of the space.0 -
This unit would make sense in the summer, but since it pulls heat from inside the building wouldn't these dividends come at a cost to our central heating loads when this is operating in the winter?
True, in Micheals case that is when it is turned off and he is running the boiler0
