Loop Off A Steam Boiler
Bob Gagnon plumbing and heating
Dan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
FHW Loop Off A Steam Boiler
Can I run 2 FHW zones off the bottom of a steam boiler?
Thanks, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Yes,
but don't exceed the boiler's pick-up factor with your combined hot-water load.Retired and loving it.0 -
flow control issue
Dan, your diagram for a loop above the boiler shows the pump & flow control on the vertical. is this critical. ? i got one with a chattering flow control on horizontal & am wondering if this could be the culprit. i have done them in the past horizontally with no problem but i guess it all depends. this particular one is two h.w. zones. ,one in bsmt. , & one that piping is extended to ceiling & then drops down & goes back up for returnback to boiler & then down again.0 -
Not to scale,
and just for concept. Could you have been passing air through that flo-check?Retired and loving it.0 -
flow-control
It is pumping away & i filled the loop with a hose connected to city pressure & bled loop. it does not seem to be constant. . last time i went there ---- no noise. picking at straws0
- 133 Chimneys & Flues
