does EPDM tubing require heat exchangers?
hot_rod
Member Posts: 25,061
steel instantaneous electric water heater recently. Built in Arizona as I recall. It was displayed at the HomeBuilders Show this spring.
That and a stainless circ pump, bronze air purger, and a DHW (coated) expansion tank you could skip the HX and extra pump, etc.
hr
hr
epdm tubing
i have the 3/8 black epdm or solaroll tubing installed in gypcrete and want to use a hotpoint electric boiler. i've heard that this tubing clogs up and heat exchangers are necessary to prevent this. only non ferrous metals can be used. any experience with this?
thanks
ron0 -
yes
You do need a heat exchanger and a plan for an alternative heat emitters when the tube and connections do fail.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 972 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
