What the flux?
Timco
Member Posts: 3,040
Here is where **** (what the flux) would work! What eats flux? I need to soak this head in something as the last guy did not flush or clean anything. The goop on the float came from up in the head, and the float was totally stuck in this stuff. Did I mention I hate glycol? Just need to not let any cats in here!
Tim
Tim
geeez, that's a lot of
That's a lot of buckets you got there, however, the question is, what tha white fluffy thing at the bottom of the pcture? Your slippers? Don't worry, I won't tell..0 -
Rohmar
Rohmar makes some great products and has a system flush that should work great in your application.0 -
Tim, Cabarator cleaner will do the trick.
Dave StromanThere was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
