Cleaning my EK-2000 oil fired boiler combustion chamber
Alan R. Mercurio_3
I agree with 3lees.
Your friend in the industry,
Alan R. Mercurio
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=408&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Alan R. Mercurio
Cleaning EK-2000 oil fired combustion chamber
Should my combustion chamber be cleaned on my EK-2000 oil fired boiler every year even though the test performed on the boiler indicated that it was ok.0 -
What test said combustion test was clean? Yes, it should be cleaned yearly, it is much easier to clean yearly then letting it sit and get hard in the chamber and heat exchanger.
cleaning
by all means it should be serviced annually. The chamber should not be removed though. The converter surface cleaned yes. It's always best done by someone who knows them. If the pork chop is knocked out from under the chamber, the front collar can and probably will tear. Excellent choice in boiler by all means. peace0 -
Doesn't EK call for a differential draft test, and if the two tests are within a certain parameter you don't have to open it up?
Just going from memory.
Ken, that is true, but it never hurts to take a look.
I agree SW, but i think that is what the op was asking about.
- 133 Chimneys & Flues
