Heating the Pool
Rich Ferris
I have a Buderus G115/4 with Logomatic and S-120 indirect to 2 zones of baseboard.
Rich
Rich
How do you guys heat your pools?
I'm a heating contractor, Yet my pool is never warm enough for me. I maintain it for my Wife and two young boys but I rarely go in myself because its just not warm enough. We nibbled at putting in a Propane heater (Just like our neighbor)(Identical pool installed by same installer 20 yrs ago for previous owners). I decided last year that I would make a Solar Heater using ABS and making a rack. This helped the Solar Cover but it still didn't do the job, As my Wife kept reminding me. I'm trying to get some creative ideas from you guys since a Heat Pump cost is really up there but less of a hassle than propane.
Thanks,
Rich0 -
Just curious Rich,
what kind of system are you using in the house?
Dave0 -
Questions
What are the dimensions of the pool? Where are you located?0 -
Dimensions of Pool
Inground 16' x 32'. 15,000 Gallons. Hartford County-Connecticut0 -
250- 350 square feet
of solar collector is a rule of thumb. 50- 70% of the surface area.
The best bang for your bucks would be pool collectors if it is just for summer time use.
Roth, SolarHot and many others have polymer pool collectors available.
RET Screen, a free download, will let you run swimming pool calcs to show you some options.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Oil usage with HX
I have several projects using a HX to heat a pool with an oil fired boiler. The pools account for 50-60% of the oil bill, which is to say the owner can expect to double the cost of the fuel bill to keep the pool at 83 degtrees. Solar pool heating is the wasy to go, as HR said.
I've also been interested in heating a pool but not with gas or oil.
I've seen this product and was wondering if anyone has any experience with this?
http://www.sungrabber.net/solar-pool-heater-how-it-works.html
I'm tempted to go Heat Pump, even though the cost maybe more in the onset, I think overall, the savings will be realized quickly.
But I still go back to these panels.0 -
pool heater
look into a WATERFURNACE poolheater0 -
Heating Pools and Spas
Rich I use a Willmark tube and shell Stainless steel heat exchanger model QHE-35 12 gpm flow on tube circuit 65 gph on shell side 150,000 BTU off the boiler add a zone and control it wihh a Honeywell T775 Ive got some out there since 1996 indoor pools year round operation still performing with no problems
Dom
- 133 Chimneys & Flues
