Steam run-out
Joe Blanks
Member Posts: 10
Hi all,
If I want to relocate a steam rad on a one-pipe system 7' away, do I need to increase the size of the run-out? The main is 2" with an 1-1/4" run-out to a 54s.f. radiator. The rad will be moved about 7' from the main to the new riser (for 1st floor radiator). What pitch should I use? 1/2" per 10' or 1/2" per foot? The riser is NOT dripped.
Thanks-
Thanks-
If you can get
1/2" per foot of pitch or thereabouts, an 1-1/4" riser should be OK.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
