propane fired steam boiler
able to buy a boiler with Powerpile unless you contact someone still making them for the Amish (they do not use power).
You could however have a local service company retrofit over to a Honeywell (VS820) powerpile valve (or Robertshaw and White Rodgers make powerpile valves also) and eliminate the AC power. This may however affect the warranty on the boiler.
  • steam
    Looking to install a propane fired tankless steam boiler. The catch! I would like it to be self sufficient no 120v. The house is very rural in Maine and may encounter long periods with out power due to winter storms. I think that at one time you could get one with a millivolt gas valve, but with the new draft hoods for efficiency they have been phased out. Is their anyone out there still producing anything like this?
  • I believe
    Burnham still makes them for the amish, they are right in the middle of Amish country.
