Heat Pumps for Hot Water
Jack Kagan
I recently reviewed a property condition report for a resort in Maui, HI. The report recommend using water-cooled heat pumps to make 140 F hot water and using the existing gas-fired water heaters as backup. Does this sound plausible?
Yes
Climatemaster makes a water to water unit called the Tranquility. It reaches temps of 140 degrees. You can see it at www.climatemaster.com0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
