Oil Tank Help
I believe the width is 24 inches . Had to use one the other day for the same exact reason . The walls were 26 inches at the most .
The 240 has the same length as the 275 , standing up . But the height when it's on the legs is higher .
  • Long Beach Ed
    Long Beach Ed Posts: 1,848
    Oil Tank Help
    Have to replace a 275 Gal basement oil tank. The problem is that access is 26-inches wide AT THE MOST. Can't find anything that will fit. Outdoors is out of the question. The old one is actually 26 inches. New ones are 27 or 28 from what I've found.
    Any ideas? Thanks, as always.
  • Long Beach Ed
    Thank you Ron, I'll look at it...
  • Granby makes a 240 gallon "narrow" tank which sounds like it would go down your basement. The dimensions are: 47" High x 23" wide x 60" long. Their part # is 202201.
