Zone valves with glycol
billtwocase
They are all vulnerable I find, and any rubber along the way. I guess it's the price you pay for freeze protection? I generaly prefer all circs and flowchecks if from day one it has glycol, but even the "O" rings in the circ start to show signs of leakage. Depending on the conditions, I try to run a lower percentage and test it yearly. peace
Which zone valve would be the best to be used considering that even with inhib. and conditioners would hold up and last the longest. Has to be full port. Have found out that over the years that any valve or IFC pump fail because of glycol. Im asuming that the plastics and rubber get attacked, any help. H/well-Rubber, W/roger-Stain steel??0 -
do you....
really need the glycol? I hate the stuff and rarly use it unless a home is prone to having the power go out for long periods of time...I understand that a main reason for glycol "failure" is system clenliness. make sure the system is clean and flushed first (Rhomar has great products)then add in the glycol... hope this helps.kpc0
- 133 Chimneys & Flues
