thermostat
Jim_67
I am adding central air to my son's house. He has a boiler for heat with a heat only thermostat that has 18-2 wire.
The air handler will be in the attic.
Can I purchase a thermostat that will operate both the boiler and the air handler? Or will I need 2 thermostats. I understand that there may be some issues with two transformers(boiler and air handler) on the same thermostat.
If I can use only one thermostat will I have to run 18-5 wire?
Yes
you can use any heat/cool stat just be sure to remove the jumper between RH and RC and wire according to instructions.
I like the honeywell 800 series stats.0 -
tony types faster then I do
DITTO I also like the honeywell pro 4000 therm.
That is impossible JK
I usually retype something 3 times with 2 fingers, then I look up and see i used all caps except the one that are suppose to be caps. You must have fell asleep or went through some kind of time warp LOL0 -
time Warp
is ThaT Like A FLashbACK or Somrthing??
WBcp
Its the box at yhe bottom that slows me down...
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
