gyp-crete
some of the manufacturer's web sites for contractors.
  • rich p_4
    rich p_4 Posts: 25
    Radiant and gyp-crete
    Hello
    We are in Massachusetts, looking for Gyp-crete contractor
    Its a large finished basement 1700sq ft
    Hoping to find a guy to give us idea of cost.
    Any input or ideas appreciated.
    Rich
  • rich p_4
    rich p_4 Posts: 25
    bump
    bump?
    hot_rod Posts: 28,529
    That's a small area
    for a gyp pour. Probably take more time to set up and clean up, than pour! It could be expensive so a small job.
    Is a regular concrete, pea gravel mix an option. Much less cost and easy to pump with a small grout pump. Or motorized wheelbarrows :)
    I have pump several 1/12" thin slabs over concrete slabs with pea gravel mix. Final floor covering can make a diference also. Thin concrete pours will crack and telegraph through a tile floor if proper application methods are not followed, like clevage membrane
    hr
    hr
