Large Solar storage tank top
Wayco Wayne_2
who has an 800 gallon storage tank for her drainback sloar system It looks like a small above ground pool in her basement. It's about 4 ft high and maybe 8 ft in diamenter. The top has fallen apart and I have to find or make a replacement. The old top was made of expanded styrofoam covered in plastic. Kind of lie a hot tub lid. Any suggestions on where to find something like that or how to make one might be better. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
maybe make a top out of rigid insulation to fit the size and
then take to fiberglass shop and have them encase in fiberglass with a lip for around the perimeter of tank, ps boat shops need the work right now. Would work pretty slick. Tim0 -
If it is 8' Dia., I would go to a home building supply house like Home Cheapo and buy 4 sheets (4 X 8) of foam with foil covering. I would lay out 2 of them side to side and cut out the diameter. Then I would take the other 2 and glue them using something like liquid nail if its compatible with foil, to the first 2 except at a 90 degree angle from the 1st two. Then cut that circumference using the first 2 as a guide. I can't imagine the cover gets removed too often so it should last a long time and it would be pretty well insulated. It would be at least 4" thick which I assume would be much thicker than the original.
Rene0 -
Thanks for the ideas
I took the top all the way off and hopped into the tank. (It was drained.
) The bottom had styrofoam too and it was all cracking and broke up. Took it out and bagged it. I guess there is some concern about heat loss through the bottom, but That being the coolest part of the tank I don't know why. I was thinking of sinking some 2 in extruded cut to the shape of the bottom. and weighing it down with cinder blocks. Then for the top I like the ides of the foil faced insulation at least for facing the water. maybe then stacking some 2 inch blueboard on top to beef up the R- values. I need a new sight glass and differential controller too. It's a 25 year old drainback. 26 flat panels. The tank is 6 foot diameter not 8. My mistake. Any improvemnts? Let me know. WW
would this be an option?
http://www.stsscoinc.com/Products.aspx
Seen a couple in the field, in 600-1000 gallon sizes. Seem to work well.0 -
KIDS!!
I like the idea of the foil faced "Home made" lid but i would recommend reinforcing it as prev mentioned with fiberglass just to prevent the possibly of someone ( like small children) falling thru the lid and getting scalded by 150 to 170F fluid .
safety ist # 1 !0 -
I agree that safety is first. I can't believe that a child could fall through a foam cover that is 4 to 5" thick. Remember, the tank is 6' wide. A man should be able to get on it. But if that's a concern, just glue on a piece of 1/4" plywood.0 -
My foam solar cover
Absorbed water into the foam, last time I had it off I painted all the edges to see if I could keep the water out. I think the round fiberglass covers made for fiberglass tanks, like AK Industries, might be a good option, if they sell the covers seperately.
Thanks, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Hot tub service companies
Most local hot tub service companies make custom covers for hot tubs. They cover the foam in vinyl and add locks. They usually contract this out to local Upholestry shops.0 -
lid
If it where mine I would fab a permanent lid with a manhole opening. No need to open the entire 6'.
Try wrapping new insulated lid with EPDM
My 2c
Metro Man0 -
Does extruf\ded
polystyrene take on water and get waterlogged? WW
Does extruded
I imagine....
it would if hot enough and wet log enough. Is that not one of the reasons when doing radiant floor under a slab they have a vapor barrier first then the Dow board on top.... IS the water in this tank potable or just act and the transfer medium through a coil?0 -
The water in the tank
is the transfer medium of the drainback system.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
