Removing Barometric Flue Damper????
Shows it right on the install pictures, make sure he wired it correctly;If your boiler fires without it open;
HELLO SOOT. (Also watch out for those pesky long sheetmetal screws.)
  • Jeff_130
    Jeff_130 Posts: 31
    Is it OK to remove the barometric flue damper?
    Hi:
    My service tech was just here and installed a Field Controls Oil Vent Damper on my old steam boiler. As part of the install he removed the barometric damper that was there, is this ok? The install diagram shows the atmospheric damper installed before the automatic vent damper... What are the possible negative effects?
    The literature for the OVD is at http://www.fieldcontrols.com/pdfs/4325OilVentDamperSS.pdf
    Thanks for the help.
    Jeff
  • Jeff_130
    Jeff_130 Posts: 31
    Hi:
    My service tech was just here and installed a Field Controls Oil Vent Damper on my old steam boiler. As part of the install he removed the barometric damper that was there, is this ok? The install diagram shows the atmospheric damper installed before the automatic vent damper... What are the possible negative effects? Will the removal of the barometric damper negate any savings that the vent damper is supposed to provide?
    Jeff
  • Paul Pollets
    Paul Pollets Posts: 3,672
    Vent Dampers v Barometric
    Vent dampers are used on atmospheric gas boilers. Barometric dampers are required on oil fired appliances or power burners. A vent damper is not used on an oil fired appliance
  • They are now
    Field just now came out with one designed for oil.
    Jeff, the tech should NOT have removed the barometric. It is crucial to maintaining proper combustion over a wide range of draft conditions. Without it, you would probably use considerably more oil then with it.
    Call and speak to his supervisor NOW. If you don't get satisfaction, switch companies.
    "Steamhead"
  • scrook_2
    scrook_2 Posts: 610
    Field OVD-4 thru OVD-8 Oil Vent Damper (new item, 4" to 8" flue sizes) installs after the Barometric Draft Control, so:
    boiler
    blocked vent switch (e.g. Field WMO-1)
    combustion test hole
    draft control (e.g. Field RC or M)
    oil vent damper (e.g. Field OVD-#)
    chimney
    He should have left (or moved if needed) the Barometric, they perform different functions! Be curious to hear how it works out.
  • billtwocase
    billtwocase Posts: 2,384
    draft regulator
    that's what it does, and needs to be put back on. peace
  • Jeff_130
    Jeff_130 Posts: 31
    Update
    After some further discussion with him he installed a barometric damper as well. Although, he placed it between the Field OVD and the chimney as opposed to between the OVD and the boiler. Any thoughts?
    OVD is working... so far. Field claims that it will save as much as 10% on fuel usage... I have an old house with a 40+ foot chimney that generates a whole lot of draft so hopefully this will save me a few bucks before I have to bite the bullet and replace the boiler.
  • RonWHC
    RonWHC Posts: 232
    The barometric
    is clearly shown between the boiler & the damper. Why? To keep the chimney draft from removing heated air from the home (as it will in its present configuration), as well as heat from the boiler.
    You pay to heat both. Keep that paid for heat away from the chimney as long as possible.
  • kpc_71
    kpc_71 Posts: 5
    I know Smith....
    on their Series 8 oil boiler to NOT install a barometric.
  • are those 5-10% savings realistic? Would I be more apt to save 5-10% on an older oil boiler than a new one? With 5-10% savings, this should be a no brainer on all new installs, right?
  • Only if
    the draft doesn't exceed their specs for the 8 series without one. If it does, it's too high, and the barometric is the cure.
    Jeff, a lot depends on the type of chimney you have. With a newer chimney it might not be such a big deal, but on an older one that can pull pets and small children to the roof, you'll save more with the damper.
  • Jeff_130
    Jeff_130 Posts: 31
    Steamhead:
    I've got an older house with a boatload of draft so I'm hoping to realize some real savings. I'll post my results (smells, etc. as well as savings - if any).
    Jeff
  • Long Beach Ed
    Long Beach Ed Posts: 1,848
    Just Keep in Mind...
    These oil dampers were quite popular when oil was priced high in the late 1970's. They were also very prone to getting stuck as soot and the garbage that accumulates in the breach foul them and keep them from opening/closing.
    Many oil companies routinely removed them because they became a service problem.
    Maintain it well and it will serve you and save you some money. I had mine for over twenty years, and while it required regular cleaning, it did save me about 5% on an older Dunkirk boiler and a 40 foot tall oversized chimney.
    Forget it's there and one day you'll come home to a cold house or worse.
  • Any feedback yet?
    Jeff,
    Any feedback yet? I am interested in having one installed if they work as advertised.
    Larry C
