poly under thin radiant slabs?
[Deleted User]
For the past twenty years I have installed polyethylene sheeting under the concrete in radiant slab heating installations that I have facilitated. For the first time I have been instructed by both the builder and plumbing inspector that the home that I am currently installing does not require poly under the thin slabs on the main and upper floors. The grade slab received poly as usual. Your comments please.
thin concrete slabs?
should have a bond breaker or slip sheet over a wood subfloor. It also keeps the wood from drawing the "waters of convenience" from the mix., which leads to cracking and too quick of a set. At least that is what the concrete experts at RPA seminars have always told us.
Now with gyp products you want to spray a bonding agent, looks and smells like Elmers glue.
hrBob "hot rod" Rohr
Living the hydronic dream0
- 133 Chimneys & Flues
