any word on thermopex?
'180degs at 100psi'. i didn't know that pex was rated that high
  • Cam_2
    Cam_2 Posts: 36
    REHAU Pex Ratings which is PEXa
    RAUPEX O2 Barrier Pipe is rated for continuous operation of:
    - 160 psi @ 73.4°F
    - 100 psi @ 180°F
    - 80 psi @ 200°F
    This is taken from the product catalog
    Not sure about PEXb or PEXc
  • thanks rick
    i know of rehau, but i didn't know their specs. i'll check it out
  • bb_11
    bb_11 Posts: 39
    All PEX
    meets the same standards for Temp and Pressure ratings. See ASTM F876. Read the print line on the pipe and it will list all of the details.
    Does not matter how the PEX is extruded.
    bb
  • Cam_2
    Cam_2 Posts: 36
    All extrusion methods are similar
    It the cross-linking process that changes high density poly ethylene to PEX is what determines PEXa b or c. which in the industry are known as the Engel, Silane or electron beam processing methods. Cross-linking changes the material from a thermoplastic to an elastomer... Fun stuff huh?
    Rick
