Dimension \"a\" question per a \"drop header\"
the dimension almost all boiler makers want for the height of the risers to the header is 24-inches above the highest permissible water level. This is to keep water from getting into the header.
Bob, that 24 inches only applies to the risers. Once they've reached this height (and preferably higher if you can manage it), they can drop pretty much to the top of the boiler if needed. This is the way to connect to any low-hanging steam mains you may have.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
