Flue Temp Computations
Mark_46
Mark_46 Member Posts: 312
Heat Transfer, Munchkin 80
  • Mark_46
    Hi all,
    Is there a standard method for finding boiler efficiency using flue temp measurements? Should the temp be compared to return water temp? Should one value be divied by another?
    I recently measured the following. This is a modulating/condensing boiler type. Is below enough data?
    Boiler set point/supply water temp = 123
    Boiler return water temp = 111
    Flue gas temp = 119
  • Todd_43
    Todd_43 Member Posts: 1
    Efficiency
    With a modcon, efficiency is directly linked to the return water temp AND the partial load percentage. The manufacturer should have a graph showing you this. What brand are you using?
